MTD Lawn Tractor won't go into reverse or forward.
MTD/Huskee acts like it is in neutral. Won’t go into reverse or forward. Pulley on transaxle is spinning. It is a 2012 LT 4200. Should I open up the transaxle?
Update (04/28/2019)
Opened the transaxle and it is the clutch collar that is worn. I will also replace the detent shaft assembly because it is probably worn as well.
Playing with WD40 and oil, got it to go into reverse, but it stays in reverse while shifter is in forward, neutral and reverse.
由 handysaint 完成的
