跳转到主内容
此为等候许久的Mac mini硬件更新。处理器方面支持选配3.6GHz四核i3,3.0GHz六核i5,及3.2GHz六核i7英特尔CPU。
85 个问题 查看全部
Macmini 2018 RAM upgrade void warranty
Hi,
I’m having T2 chip problem with my Mac mini 2018, and also i upgrade ram my self 8gb to 32gb. so can i claim apple warranty for T2 chip problem?
Also, I purchased my mac mini from USA but i live outside USA. how can i claim warranty?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
What issues are you having with the T2 Chip?
As for the warranty goes, while you may be able to get away with sending the 32GB ram in with the machine but I would reinstall the 8Gb before sending it in. You can visit any apple store for the repair or just call the support number.
这个答案有帮助吗?
得分 2
3条评论:
Thanks for your answer.
I am getting random reboots and glitch screen, Sometime it’s don’t show for a day some time 2/3 times a day.
I’m using latest version of macos mojave 10.14.4
There is no hardware error with apple hardware check.
{"caused_by":"macos","macos_system_state":"running","bug_type":"210","os_version":"Bridge OS 3.3 (16P3133)","timestamp":"2019-03-05 19:25:49.76 +0000","incident_id":"EA706255-8D43-48A8-81C4-DF5240B37CC7"}
"build" : "Bridge OS 3.3 (16P3133)",
"product" : "iBridge2,5",
"kernel" : "Darwin Kernel Version 18.2.0: Wed Jan 2 20:41:23 PST 2019; root:xnu-4903.241.1~3\/RELEASE_ARM64_T8010",
"incident" : "EA706255-8D43-48A8-81C4-DF5240B37CC7",
"crashReporterKey" : "c0dec0dec0dec0dec0dec0dec0dec0dec0de0001",
"date" : "2019-03-05 19:25:49.72 +0000",
完成的
Hmm, what makes you suspect the t2 chip then?
完成的
iBridge2,5 & RELEASE_ARM64_T8010 cinch's the T2 is having problems. There's been quite a few reports on this issue.
完成的
添加一条评论
Yep this is a T2 problem. You’ll need to put back the Apple memory then bring in the system. technically you shouldn't need to swap the RAM again. Some Apple employee’s give people a hard time when they’ve upgraded their Mini’s, unlike the 27” iMac’s you need to pop the case off.
Double check your RAM is the correct spec.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Shokat Jamil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,644
