跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Liquid damage, Now running slow with overactive fan.
Had a water bottle next to my bed and accidentally knocked it over in the middle of the night onto my mac.
The following day I opened it up, my track-pad was over-responsive, wifi didn’t work at the time either. Wifi and trackpad are working again since I let it air out. However, the slow processing speed has not changed.
There was some corrosion noted near the track pad connecter/cable on one side, otherwise there was no other obvious signs.
The fan is over-working also present on start up.
Can anyone point me towards some resources? I am a novice with Mac repairs, however am comfortable replacing my own display for my iphone if this helps with my skill level.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hey Matthew,
Sounds like a Sensor is damaged. This causes the Computer to think its running a lot hotter than it actually is and throttles down the CPU and runs the fans high. You can use a Sensor Checking software to see what sensor it is.
Sensor check software: http://www.tunabellysoftware.com/tgpro/
If it’s the trackpad sensor you will have to deal with prying out the battery carefully for replacement, otherwise its going to be a Motherboard repair, it shouldn’t be too big of a deal for any repair shop offering micro soldering. As long as they know what they are doing :P
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matthew McClelland 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 41
