跳转到主内容
The Wii U is a video game console paired with a handheld device made by Nintendo that allows users to play games on the GamePad. Repairing the console is straightforward as the device is very modular.
Wii U Not starting; Blinking red light
i was recently wanting to play on my Wii u for the first time in a month or so. the light tuns on blue for a second with the fan coming on then blinking red light. it has been opened recently to be cleaned. any ideas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
J'ai ma Wii U qui affiche un voyant rouge tout en clignotant quand je tante de l'allumer, et le ventilateur à l'arrière de la console ne tourne pas. Que dois je faire?
I have my Wii U flashing a red light while flashing when I try to turn it on, and the fan on the back of the console is not spinning. What should I do?
完成的
添加一条评论
4个答案
最有帮助的答案
I know this is an old post, but if you opened up the console and removed the disc drive, be sure to plug the flex cable in the same way it was removed. You can swap the cable around and it will fit, however you'll get the blinking red light when you try and turn it on.
这个答案有帮助吗?
得分 3
1条评论:
thank you!!! :)))
完成的
添加一条评论
Make sure plugs are all plugged in. Did u have a game in it? Try to get it out and try again. Or maybe you left it on last time you played which can overheat it
这个答案有帮助吗?
得分 0
添加一条评论
https://www.bing.com/search?q=How%20to%2...
这个答案有帮助吗?
得分 0
添加一条评论
Nothing is helping my Wii U it is always just a blinking red light I don’t know what to do anymore I try cleaning it and cooling it down I left it unplugged for over a month came back and still just a blinking red light.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jake 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 42
总计 1,944
