My lens is stuck.
I've tested the battery and it is fine. I've removed the memory card and held down the function button while turning the camera on. This hasn't solved the problem - the lens is still stuck. What else can I try?
Irene Rosko, take a look at this blog. It does describe in detail how to deal with this very common error. Should any of those steps not clear up the problem, then I would think that your issue is related to the IC that controls image processing. If it has failed you will have to replace that. But try the less invasive suggestion first. Good Luck.
这个答案有帮助吗?
My. Camera is a sz1114 megapixel
Olyumpus 20x wide
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 11,935
1条评论
من احتیاج به یک شارژر و یک باتری دارم برای دور بینم! باید چکار کنم؟
由 Mohsn Jafri 完成的
