跳转到主内容
苹果订单编号为MC007LL/A / 27" 2560x1440 分辨率的显示器。
78 个问题 查看全部
Moving Lines (marching ants)
From left to right I’ve noticed a series of lines roughly spaced 1cm apart across the entire screen. These are not consistent but more like moving pixels that look to be moving from the bottom of the screen to the top, they’re really faint however having noticed them its now something I can’t not see, any ideas? is this a sign of impending death?
IMG_2367.HEIC
IMG_2368.HEIC
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Can you take some pics or a short vid and post them here for us to see 在已经存在的问题里加入图片
完成的
here you go dan :)
完成的
Sorry I don't see the lines, the vid is a bit blurry which could be hiding it.
Take some stills at the highest resolution and you might want to use a stack of books to help steady the iPhone.
完成的
struggling to upload images for some reason but looks like this
https://www.youtube.com/watch?v=ozX3RmgM...
完成的
OK I see the issue!
Let narrow down possible sources of the issue
First do you see this on other external monitors? If you have an iMac do you see it on the iMac's screen as well? What is your system and the video board?
Are you using a surge suppressor which both the system and the display are plugged in?
Have you altered your systems config in any way?
Does this effect come and go?
完成的
显示更多的2条评论
添加一条评论
1个答案
最有帮助的答案
I’m starting to think the T-CON board on the backside of the LCD panel has an issue. If you can find a panel which is cracked you should be able to salvage the T-CON board from it. The other option is getting a replacement panel. I’ve seen some listed on eBay for around $250 USD often I see them listed around $500 USD.
Heres the part info: Apple LED Cinema Display 27" A1316 LCD Screen Panel LM270WQ1 (SD)(B1) - Apple P/N 661-5542
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jack crowther 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 388
