Why did my screen stop working?
I recently replaced the LCD screen cover on my Mac. When I started my laptop afterwards, the screen lit up, but I could only see a white screen and image outlines. Should I replace the display cable and inverter.
If the device works fine on external screen then you should consider that screen cable got loosen on connector on LCD or MoBo.
If you’ve managed this repair on your own then I would suggest you to check the cable and secure the connector with electrical tape in order to prevent losses. You should also be aware if the cable got damaged (especially on hinges) and probably try to clean the gold pins (if you’ve ever detached cable from screen)
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 76
4条评论
Post a picture?
由 Steve 完成的
[image|1742953]
I connected an external monitor and everything works fine.
由 [deleted] 完成的
[image|1742953] Not sure if the photo is uploading.
由 [deleted] 完成的
Here's how to add images to your existing question:
Adding images to an existing answer
由 mayer 完成的
