跳转到主内容
Can I change my logic board originally in 2014 early to mid 2012's?
I have a old laptop which is 1.4 Ghz and 121 flash storage. Recently I would like to buy some 2012 8gb 2.0Ghz logic board to replace the original logic board. Is that doable and is there any recommendation or advice?
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
hi
just so i understand correctly, your are wanting to downgrade from 2014 l/b to 2012 l/b?
完成的
添加一条评论
1个答案
已选择的解决方案
From what I can tell from your post, it’s sounding like you have a 2014 MBA and would like to install a 2012 Logic Board into it.
If this is the case, it will not work. They are completely different boards and are not compatible. The 2013 - 2014 board is what you want. I believe a 2015 - 2017 boards should work fine too, haven’t had a chance to test this personally though. (Upgrade MacBook Air A1466 i5 2013 logic board with a newer one 2015)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Alex Lupu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 69
