跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
IPse keeps rebooting after water damage
I recently bought an iPse from eBay that was water damaged. When I received the phone I didn’t bother to turn the phone on, I disassembled the phone completely and did a clean on the phone with mg99% iso. There was no sign of corrosion on the back part of the board it was mainly on the digitizer and lcd and camera connections. So after about an hour or so of cleaning I left the board to fully dry. I left the board to dry for about an hour also once finished and made sure everything was completely dry. I reassembled the phone and turned it on, but once I turned it on it had a lock on it so I had to do a dfu mode recovery to remove the lock on it. Once that was finished I was able to Use the phone as a new phone. Everything was working on the phone sound, brightness, front camera, vibrate, Touch ID,etc. but once I got to the camera I noticed it was just black no image at all it shows that your in the camera mode but you can’t take any pictures. Then I tried using the the flash trough the camera app and it wasn’t working, so I tried using it trough the control center and it wasn’t work on their neither. A couple of key notes that I didn’t mention was that the battery I was using was an aftermarket battery that I had on another se, i used this battery since the other battery that it came with was water damaged. Not sure if the battery is the cause of the restarting but I can’t figure out why the camera isn’t working, i changed the camera with another camera that works and it’s the same just black(at least 4 working cameras). I looked at the camera connection on the board and they look good, the only one i noticed was a littl off( as in one of the pins are black and not making good contact at least from my observation) was the digitizer conecctor but the touch works good on the phone. So my question is what would be my next step into figuring out the problem. Or is it the digitizer connector? Any advice will help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
so hold on , your front camera and flashlight dont work, your phone shuts off randomly and restarts
if im getting this right, I remeber going into a repair shop once and heard a guy mention "I had nicked a cable" but im not sure that's the case , the water damage to the phone must have gotten into the affected components ports, Also if the phone is randomly restarting, check the connection between the battery and the pin connections between the cable and motherboard, they could be loose, corroded, damaged, ect. if its none of those its the battery thats causing the rebooting problem
这个答案有帮助吗?
得分 0
2条评论:
My front camera works but the back camera and the flash don’t work. I looked at the board and can’t find any sign of corrosion but then again with water damage you never know. I’m just waiting for some parts to arrive and I’ll run a couple of test and hopefully find the solution. Thx for the advice Brayden.
完成的
ok tell me all the steps and everything you used to attempt repairing that phone I am going to try out a theory
完成的
添加一条评论
添加你的答案
Scott Sanchez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 45
