跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 个问题 查看全部
Ipad will not charge, battery is good
So I have tested the battery with a multimeter and got a reading of 3.0V but the device will not turn on or charge. I have tried a hard reset and no luck. Is there a way I can determine if it is the logic board or the dock connector other than trial and error
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Its got to be the charging port (dock connector) alone and not the battery or logic board.
Good luck bud
这个答案有帮助吗?
得分 2
1条评论:
unless when open you see the dock connector is broken on the motherboard too/ then motherboard replacement may be necessary
完成的
添加一条评论
添加你的答案
Ryan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 29
