跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB DDR5 Video RAM
499 个问题 查看全部
My MacBook cannot start up
Hey guys, My MacBook suddenly can not start up. Mega safe light do not turn on. press the power button do not have any reaction. Changed a new battery still do not work. Remove the battery connect directly to megasafe still the same. Even tried different megasafe. Can you guys please help me.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
2个回答
已选择的解决方案
If you have no green light there’s a fault on the initial stage of power lines creation, reasons may be a few, a bad aftermarket charger may cause damage to the charging circuitry and the protection circuit. There could also be a short somewhere else taking down main power circuit, it’s pure guess without thoroughly testing the logic board.
It’s not a typical DIY task, your options would be replacing the logic board or finding a lab performing component level repairs, best if with specific experience on Macs.
这个答案有帮助吗?
得分 2
添加一条评论
open up the bottom case and try another magsafe/ I’ve ran thru 2 new ones before the light illuminates again/ also may need a new MOTHERBOARD and RIO BOARD. Hopefully only a MOBO
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hulk 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 30
