跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for Trio tablets on the Android operating system.
How to update os on Trio STEALTH G5 7.85?
when i am trying to update os for Trio STEALTH G5 7.85 tab, its showing your system was damaged wireless update was disabled. Please give the suggestion for this problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset.
  6. UPDATE 6/1/10
  7. Apply update from ADB: The Android Debug Bridge allows you to plug your device into your PC and issue commands from there. It’s designed for developers and requires you to install the Android SDK (software development kit). If you’re interested, you can find out more at the Android developer website.
  8. Wipe data/factory reset: This will wipe all of your data — photos, videos, music, apps, everything — and return your phone to its original factory condition. This will also wipe the cache partition.
  9. Wipe cache partition: This is temporary system data largely related to app installations, and you can delete it without losing any personal data or settings. Wiping the cache partition can solve a host of issues and you won’t lose any data or settings, so there’s no real risk involved. We recommend this as a fix for a lot of common Android problems. NOTE: Since it released Android 7.1, Google has removed the wipe cache partition option for devices that get seamless updates. You should be able to do the same thing by going to Settings > Storage and tapping on Cached data.
这个答案有帮助吗?
得分 2
1条评论:
Once I've done those steps this black screen with blue writing comes up and says Android system recovery what option do I select? I have three options which one do I select to do a full update?
Apply update ADB
Apply update from EXT
Apply update from cache
完成的
添加一条评论
添加你的答案
Satwik Chittampally 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 15
总计 3,648
