Doesnt power on but charges battery and fuse ok
Hi everyone!
Got a dsi which doesnt power on but charges fine with a solid orange light. No fises are blown as I continuity tested them. Heres what I already tried
. Changed the battery to a new one
. Checked both fuses and they are both good
. Double checked all ribbon cables and they are all firmly attached
. Checked with a multimeter if voltahe was getting to the motherboard from the power board and it is working fine
. By the way, this has no water damage and no corrosion on the board
I'm not sure what else to try…
I press the start button and nothing happens. Kept it pressed for almost 2 min, still, nothing. Not even a blink on the screen or a blue led flash.
Any ideas??
Added couple images of the board in case someone sees something I missed?
Thanks!
Aren’t there two boards? Where are the capacitors?
由 Nance 完成的
