跳转到主内容
Repair guides and support information for televisions manufactured by RCA.
181 个问题 查看全部
Tv will power on and then power off
I've solved this before but unplugging it. Now I cannot get that solution to work. At one point I unplugged the hdmi and was able to get the cable channels to work. Powered it off, plugged in hdmi, powered devices back on, and the problem started again. How can I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@amyrstiffler
if video sources other than your HDMI work t is most likely the main board that is the issue here. 3rd picture shows the main board. If it does not work with any input source you will have to measure the voltages from the power board to the main board.
这个答案有帮助吗?
得分 2
2条评论:
I was able to get it to recognize a different hdmi device, but then it powered off again.
完成的
TRy something different than your HDMI. It still sounds like it's your main board just needing to checking other input sources
完成的
添加一条评论
添加你的答案
Amy Stiffler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 54
