跳转到主内容
加入维修社区 - 创建账户
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
iPad won't charge reliably; Lightning connector bent
I’m fairly sure the Lightning connector on my iPad Mini 2 bent when it fell off the bed while charging. I can charge it if I pull up on the cable (toward the screen), but then it stops charging when I let go.
What’s the best way to remedy this? I think if I could get to the connector, I might be able to bend it back into shape, but I don’t know if that’s possible without removing the entire logic board. Does anyone have an idea of how to fix this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You will have to replace your charging port. For the meantime if you want to bend it back into shape use a non static tool like a Spudger and when you do that make sure your iPad is off.
A tougher take on a favorite multitool. Safely poke and pry with this tough, firm, and antistatic tool for electronic repair. 5” carbon fiber tool essential for smartphone or tablet disassembly.图片
产品
Spudger
$3.99
这个答案有帮助吗?
得分 0
2条评论:
You can replace the charging port on this device? I thought that it was soldered to the motherboard.
完成的
Yes you wont be able t do it by yourself.
Where you able to bend it back into shape?
完成的
添加一条评论
添加你的答案
Calion 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 380
