Why can I not get Prime movies, but I can get TV series on my Kindle?
Kindle keeps saying ‘internet connection required’ when everything else requiring an internet connection on my kindle works. Help! Missing my enjoyable Prime movies.
Before you stream a movie or TV show, make sure your Kindle Fire is connected to a wireless network. To learn more, go to Connect to Wi-Fi.
Note: Not all videos available in the Amazon Video store are available in the Prime Video catalog. With an eligible Amazon Prime membership, you can instantly stream Prime Videos to your Kindle Fire or download selected Prime Videos to watch later.
If you experience an error while using Amazon Video, visit the Amazon Video Errors help section.
Tip: You can connect your Kindle Fire HD to a high-definition television or monitor using a micro-HDMI cable. To connect your Kindle Fire to your display, make sure both your Kindle Fire HD and display are turned off, and then plug the micro-HDMI cable into the micro-HDMI port on your Kindle Fire HD. Connect the other end of the micro-HDMI cable to the HDMI port on your television or monitor, and then turn on your display and Kindle Fire HD. Once connected, you can watch your videos, view your photos, and play your games on a larger screen.
这个答案有帮助吗?
Thank you for your help.
Try resetting your tablet Because it sounds like it’s only a soft wear issue.
这个答案有帮助吗?
Thanks for your answer. Tried that two times, to no avail.
Are you sure it's not a network issue?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 289
1条评论
Thanks, although what you recommended did not help, I appreciate you answer. After working on this problem for 4 hours, I did find a work around
由 beebretz 完成的
