跳转到主内容
修复你的物品
维修的权力
商店
The Samsung WF361BVBEWR is a front-load washing machine with a total capacity of 3.6 cubic feet.
12 个问题 查看全部
Why is the drum leaning back and hardly spins?
My washer started making a lot of noise on spin cycle. I realized the drum is leaning in the back I already replaced the shock absorbers but it did not fix my issue. Any help is greatly appreciated. Model number WF419AAW/XAA
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
1个回答
已选择的解决方案
Cause 1
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing as an assembly if the manufacturer offers the components together.
Cause 2
Tub Seal and Bearing Kit
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. If the washer is noisy during the spin cycle or is leaking from the bottom of the tub near the transmission, the tub seal and bearing are likely defective. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing the outer tub and bearing at the same time.
Cause 3
Rear Drum with Bearing
The rear drum has a bearing or bearings in it to keep the inner tub spinning smoothly. If the tub bearing system is defective the washer can become very noisy. On some machines bearings are sold separately from the rear drum, however we recommend replacing both the outer drum and bearing as an assembly if the manufacturer offers the components together because removing and pressing in the new bearing can be exceptionally difficult. Be aware that replacing the outer tub and bearing is also not easy and can be very costly.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jenny cash 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 7
过去的30天: 26
总计 396
