跳转到主内容
1.83 GHz Core Duo 处理器 或 1.83, 2, 或 2.16 GHz Core 2 Duo处理器 A1208 (EMC 2104/2110/2114/2124)
201 个问题 查看全部
Very slow install and file transfers
My imac 17 core 2 duo OSX 10.4.7 2 gig RAM is really slow. Fresh install of original disks took 2 days. I did the "rember" test and disk verify - both came back okay. File transfers also take forever. DVD plays okay. Movie from portable hard drive plays okay. Transferring files - takes forever. Unable to multitask while transferring files (itunes song and transferring a file from USB). Have not installed other programs or been online since fresh install.
Hard drive bad?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
5个答案
已选择的解决方案
I would get my data backed up ASAP. This is most likely a failing hard drive. RAM does not slow down. You can try to go in and reformat the hard drive using the "write zeros" option to map out any bad blocks but frankly I would just replace it.
Apple iMac "Core 2 Duo" 2.0 17-Inch Specs
Identifiers: Late 2006 - MA590LL - iMac5,1 - A1208 - 2114
这个答案有帮助吗?
得分 3
添加一条评论
I am having the same problem with mine. I was curious if you solved your problem and how. Thanks
这个答案有帮助吗?
得分 0
添加一条评论
It sounds like a bad hard drive mine did that a few months before it crashed. Install a new drive and that should solve it.
这个答案有帮助吗?
得分 0
添加一条评论
It was the hard drive.I still don't understand why I didn't get an error message, but it was definitely the hard drive.
这个答案有帮助吗?
得分 0
添加一条评论
maybe your HDD are full and have not enough space for OS
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gary Hewgley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 766
