跳转到主内容
Repair information and troubleshooting for the RCA Voyager III, a 7 inch budget tablet that uses Android 6.0 OS and can access the Google Play app store.
34 个问题 查看全部
Won't finish updating firmware
Basically, I turned it on. I turned on the WiFi. I started a firmware update. It's showing a black screen, with a ring in the middle. Along with a loading bar that says “installing system update". Every time the bar fills, it resets. Shows the RCA logo screen. And goes, right back to updating. I can't click on anything. And it's been about, 13 or so hours. Any suggestions, on what I should do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
It seems like you have something you shouldn't on the device. Bad app, virus, malware, etc. A normal update won't cause problems, even if you don't install it. Try starting up in "Safe Mode" and see if it happens in there. If it is one of those problems, it shouldn't happen when in that mode. You will then have to remove whatever is the cause to resolve the problem.
To get into "Safe Mode" please do the following.
1. First turn off the tablet.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe mode: ON" or something similar.
4. If you wanted disable it, simply repeat the steps above, and you should see "Safe Mode: OFF" rather than on.
Hope this will help you.
这个答案有帮助吗?
得分 2
2条评论:
It's not going to safe mode it just keeps restarting please help?
完成的
@Susan Jackson A reboot loop can be a result of various issues, including corrupted drivers, faulty hardware, and malware infection, among others. Make sure troubleshoot everything. Or kindly check out the post. https://www.partitionwizard.com/partitio...
完成的
添加一条评论
添加你的答案
Grim law 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,498
