跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
910 个问题 查看全部
问题已关闭
Anytime crazy lines appear HHEELLPP
I had it working but i slammed on the power then when i start it it shows lines and restarts in classic mode
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Need a bit more information about what you are trying to fix. What lines? When do they appear? What did you fix, or install? How did you "slammed on the power"?
完成的
DUDE they appear when i turn it on there lines that i get no apps i did not install anything i broke the power and home button -_-
完成的
Well dude, I guess it's time to like open it up and re-evalute the damage. Looks like you need some new parts. Like here is a good start...iPod Touch 4th Generation Repair
完成的
i dont need a screen i need a home button the home button is cracked -_-
完成的
添加一条评论
3个答案
最有帮助的答案
First, I would suggest restoring the software using iTunes. Just plug in your iPod to your computer, open iTunes, and restore the system (make sure your music is all backed up in iTunes first).
If, after restoring, it is still showing lines, then probably you need a new LCD screen. They're not currently available on iFixit, but you should be able to buy one on eBay, or send it in for professional repair.
Let me know if you still can't get it!
这个答案有帮助吗?
得分 1
评论:
I don't have any apps that say itunes in classic mode and i need a home button
完成的
you are still looking for the same button? this question is almost a year old...:-) Did you not check the link that I posted in December? Here is where you can get the button http://www.amazon.com/Home-Button-Apple-...
完成的
ok i just needed a button i will follow the steps
完成的
添加一条评论
Here is your LCD screen, iFixit sells it!
iPod touch (4th Gen) Screen
iPod touch (4th Gen) Screen图片
产品
$29.99
这个答案有帮助吗?
得分 1
评论:
i needa button
完成的
添加一条评论
Try this link
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 1,147
