跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
I’m missing this white film for the light sensor.
When I replaced my phone yesterday with an oem screen I realize that the light sensor didn’t work anymore. The auto brightness adjustment in my setting is on and I’ve tried to pin my phone to a light bulb, nothing. Also my flex cables and everything are in place perfectly and screwed in right. Then I did the research and found out that I was missing this rectangular shaped white film that was supposed to be in front of the light sensor. I just wanna know if that is what is causing the problem or maybe it’s a defective sensor. If it is the white film, where can I buy them?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
If you still have your old screen, installing it on your iPhone together with the front cam flex. Home button doesn’t have to be transfered for the phone to function. If it does work, you’ll know that the problem was the missing film. If not, your front camera flex might’ve been damaged while removing it. The sensor is not attached very tightly so it can break off of the cable quite easily.
这个答案有帮助吗?
得分 0
添加一条评论
Phone may not boot and the screen may not even work without the home button connected.
Are you 100% clear that it is the light sensor not working or the proximity sensor?
I have never seen that white film on any of the screens I have replaced. Try this app to test which sensors are working. I am not sure, but the camera may be the one that is used for the light sensor.
The app is free and brilliant.
https://itunes.apple.com/gb/app/testm-ch...
这个答案有帮助吗?
得分 0
3条评论:
I downloaded the app and did a full test and the only function that is not working is the ambient light sensor.
完成的
Tbh with you when I repaired when I disassembled my old screen I’m not sure it has the white film but I know for sure light sensor worked on my old display.
完成的
Ok, so the front microphone goes in the area where the white piece is. The proximity sensor fits into the bracket. That looks 100% ok to me, so you have either got a damaged front flex cable / connector or some sort of damage to the board. This is not screen dependant, so trying your other screen will not make any difference. Check the proxy flex connectors and look around the connector on the circuit board to see if any components have been dislodged.
完成的
添加一条评论
添加你的答案
MrCatsoup 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 170
