跳转到主内容
Annoying static noise on realtek integrated audio
This has been an ongoing issue. The problem got temorarily fixed when It automatically installed an nvidia sound driver along with my video card, however after rebooting the problem promptly returned. Here’s whats going on: https://www.youtube.com/watch?v=FbOHncQs...
Before any of you ask, Yes I’ve tried reinstalling the driver, Yes, I’ve tried disabling the realtek driver and it refused to use the nvidia one.
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Is nobody going to help?
When does this sound happen? Right after you power on your computer? Is it still there if you mute the sound with software? Does it ramp up according to your volume control? Does any other sound play, or is it only always noise?
Going to record and upload a video. It starts shortly after booting into windows then goes away when it starts shutting down. I am going to set the speakers to full volume in the video so you can hear it.
Did something change for this to start happening? Software install/update? Does any other sound play other than noise?
显示更多的4条评论
添加一条评论
PC 笔记本电池
An easy fix for a big power boost.
现在开始购物
PC 笔记本电池
现在开始购物
1个答案
最有帮助的答案
Hi @connor2003
good day
please list down your pc components, e.g. using laptop or desktop.....
if using desktop please list down the parts...
e.g. power supply, etc
sometimes this issues, can be due to some issues,
e.g.
OS issues,
Power supply not clean
soundcard issues
mainboard issues
grounding issues
try running for a long run with a linux live cd, and play some music for an extended time... are there any distortion?
这个答案有帮助吗?
按维修分数 1
评论:
Dell Inspiron 3847 with stock oem dell motheboard
Intel core I5-4460@ 3.20 ghz
8 gb ram
Sandisk SSD plus 240 gb
EVGA gtx 1050
EVGA 750 N1 750 watt power supply
The sound card is built into the botherboard
the power supply, ssd, ram, and graphics card are brand new.
Hi Connor
Suggest you to update bios and test run in a "live linux environment"
https://www.linuxliveusb.com/
http://www.knopper.net/knoppix/index-en....
How is that supposed to fix my sound issues? For security reasons, I am not going to do that.
I end up buying a dedicated or external sound card to avoid the static noise issues.
添加一条评论
添加你的答案
Connor 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 10
总计 114
