跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
447 个问题 查看全部
iPhone XR rattles when vibrates/ restarts constantly
My XR has been weird today. Before today sometimes it froze apps and it would fix in 3 seconds like normal. But today it has restarted many times. Installed the latest update but it still does it every 30 mins or so. It makes a weird noice (rattle) when it vibrates. I realize this could be a hardware problem. It accidentally fell from my pocket while sitting today but it wasn’t a major fall, could the rattle be because of that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The rattle is likely because the screws that hold the hap-tic engine in place became loose after the drop. Also, if it has been restarting after the drop it is possible but unlikely that the battery connection is loose. The restart and freezing could be corrupt software. I would try installing the OS with 3uTools if you can. Furthermore, there may be an issue with the board itself.
  1. I would try to reinstall the OS using 3uTools if you have a windows computer. Try the retain user data first if that fails. Try complete clean install.
  2. Test a new battery
  3. If none of these options work send it to a qualified logic board technician
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Javier Velez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 1,754
