跳转到主内容
Guides and repair information for televisions made by ProScan.
16 个问题 查看全部
Status light won't turn on, the won't work
I have a Proscan 33” LED TV (ATSC tuner). I came home and went to turn it on, and the status light flashed and clicked then shut off. I tried resetting. I reset it three times with no luck. Unplugged it as well and tried again. No luck. Idk how to check the mainframe or whatever its called or what to look for. Please help, gaming is what keeps me sane and I can't afford a new TV for awhile.
The model number is CN32XB720
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @toxxic_carress ,
If you have a DMM (digital multimeter) or you know anybody who has one and who knows how to use it, use its’ Ohmmeter function check that the fuse and the surge suppressor on the Power board are OK.
You’ll need to remove the Power board from the TV to test the fuse and the suppressor
Here’s an image showing where the fuse (red box) and the suppressor (red arrow) are located on the Power board.
(click on image to enlarge for better viewing)
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
@toxxic_carress
you want to start checking your power supply. For that you will have to remove the back and check the fuses on your board. Take some good pictures of your boards and post those with your question. That will allow us to see what you see. Also, we need to know the exact model number for your TV.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lexi Thomas 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 4
总计 303
