跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
186 个问题 查看全部
Custom screen adhesive strips not sealing.
Replaced screen using custom adhesive strips & heating pad… pops loose. Bought second set of strips & tried again… still pops loose in the middle of two edges.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个回答
First things first, make sure the aluminum chassis is straight and not bent.
Buy a roll of Tesa 61935 adhesive from reputable vendors like iFixit, this tape is far better than 3M or ”red tape”.
Tesa 61395 Tape
Tesa 61395 Tape图片
产品
Tesa 61395 Tape
$5.99
这个答案有帮助吗?
得分 0
添加一条评论
Agree with @ samy , as well before applying new strip, clean frame with ipa to remove any skin oils or adhesive leftovers. After applying strips and sticking screen on , add some books all over the ipad and leave it for at least several hrs in room temp. Adhesive strips needs some time to make a good bond
这个答案有帮助吗?
得分 0
添加一条评论
Did the ipa & books technique. However, I see now that the careful straightning of all edges & verifying (before reassembly) is essential for a good seal.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Weyland Wong 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 60
