跳转到主内容
Repair guides and support for motorcycles manufactured by Kawasaki.
20 个问题 查看全部
oil leak from water pump
I have a oil leak coming out of the drain tube from water pump ,thinking it may be coming through seal around water pump shaft , there is no sign of coolant in engine oil this on a Brute force 650 4x4i , 2006
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
It sounds highly likely that you are correct on the bad seal or gasket (not limited to the water pump shaft). If the oil pressure is higher than the coolant pressure that would explain no coolant in the oil.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Danny Rabon 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 25
总计 1,334
