Upgrade CPU from 7700k to 9900k
Hello
It is possible to upgrade my iMac 2017 i7 7700k with the new 9900k 8 core ?
Romulus - While I commend you or your tenacity! You face a few road blocks that prevent you from doing this.
Apple limits the system BIOS (EFI) to the CPU’s of the systems series. So technically your system is limited to the CPU’s in this set of systems iMac18,3
While Apple has just introduced a new set of iMac’s iMac19,1 and Apple now offers an iMac with a 3.6 GHz Core i9 (I9-9900K) we don’t know what Apple did internally yet.
It might be a simple swap out of the CPU if Apple only updated the current EFI firmware with the chips ID, or it may require manually updating the EFI chip.
As far as the systems cooling I strongly recommend you don’t try de-liding the chip! Intel is now soldering the lids on to improve the thermals. All you’ll do is damage the chip ($$$) So don’t do it!!
Also don’t use liquid metal TIM!! The mounting of the CPU allows the TIM to slowly leak out and the heat sink will be damaged by it as well.
Why don’t you wait a bit until the IFIXIT (or other group) teardown team has has a chance to review the new system before jumping.
If you really need this level of performance now I would recommend you just buy the new system or get an iMac Pro which offers much better performance options with the Xenon CPU’s
这个答案有帮助吗?
I’m not sure if Macs have restrictions in the BIOS that could restrict it.
The 2 processors use the same socket so it should work. The biggest problem I see you having is cooling the 9900. They get much hotter and I doubt you have any options on upgrading the cooling components in a mac.
这个答案有帮助吗?
Thank you for the answer ! :)
I hope to fix the temperature whit a delid and thermal past with metal liquid, I hope is enough, thanks
Hi romulus have you tried to replace i7 7700k with i9 9900k on imac 27 2017? It can work?
I ‘ll want to upgrade cpu to 9900k but I didn’t found any feedback
Thanks
这个答案有帮助吗?
It's impossible to install 8th 9th gen Intel core on 7th gen motherboard, regardless of the motherboard brand, although they shares the same physical socket.
这个答案有帮助吗?
Have you done it? What happened?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 2,100
2条评论
The CPU specs:
Intel Core i7-7700K Processor
Intel Core i9-9900K Processor
由 Dan 完成的
I'm curious to know if you went ahead and tried this…
由 Carlos Ferrari 完成的
