跳转到主内容
How can I clean this?
So, i just cleaned my laptop screen with toner, and after that idk, just found my screen like in this photo, and please help me to escape this. Thanks.
Update (04/02/2019)
Thanks for your respon,
I wipe the screen with cajuput oil, and this mark still there, so what should i do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
What do you mean you cleaned it with "toner"? Does the affected area feel rough when you lightly glide your fingers across it?
完成的
添加一条评论
2个答案
已选择的解决方案
Sadly I suspect you’ve damaged the LCD cover glass or the LCD panel its self is damaged. You need to be very careful as solvents and oils can damage it.
At this point you’ll need to live with it or replace the display 2011年末 MacBook Pro 13" 一体化机型显示屏更换. You might be able to replace the cover glass following this guide MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement picking up at Step19 from this guide.
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD图片
指南
难度:
非常困难
MacBook Pro 13" Unibody Late 2011 显示屏图片
指南
难度:
困难
45 minutes - 1 hour
这个答案有帮助吗?
得分 3
3条评论:
I'm betting predisposed damage being present and then cleaning it exposed it. I deal with it from time to time on exposed panel notebooks and displays. Usually scratching that was hidden before I cleaned it.
Unless the OP used something harsh on it (plausible since it's not something that's indicative of typical predisposed damage), that's the only possibility.
完成的
@oldturkey03 - AOK ??
完成的
all good! Thank you.
完成的
添加一条评论
From the picture I cant tell if that is on the outside or inside of the glass. If it is outside then use a microfiber cloth and scrub it off. If it is on the inside then it is probably condensation on the inside from the cleaner you used. In that case my advice would be to give it time to dry .
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dian Fathri Wardana 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 133
