跳转到主内容
The Kenmore Elite HE3 is a washing machine by Kenmore.
668 个问题 查看全部
washer turns on but no lights Nothing
Our washer turns on but no lights Nothing but when we unplug it the lights show then turn off
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
YourstrulyMerce Fonseca what's the complete model number for your washer?
完成的
添加一条评论
2个答案
已选择的解决方案
Take the back off and use a multimeter to start tracing the electrical continuity. Look for loose or disconnected wires or possible cold sold joints/. Check the fuses for continuity.
Digital Multimeter
Digital Multimeter图片
产品
Digital Multimeter
$19.99
这个答案有帮助吗?
得分 3
添加一条评论
I did not use a Kenmore washer, but I had a similar occurrence. Have you checked the fuses inside the washer? The fuse box location should/will be in the instructs. If you don’t have the manual, go to where you purchased it and ask. If that is not possible, there are instructs for EVERYTHING on line… good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
YourstrulyMerce Fonseca 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 99
