跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
iPhone se logicboard replacement
This board is from an se I have and I wanted to replace the broken parts that you see on the picture, I have another se board that’s exactly the same. Can I desoder the parts from that board and soder them back on to my se board. I’m still new at soldering but I’m planning on using mini soldering tweezers. Any advice would be much appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thank you for the reply I took your advice and didn’t touch the board. I’ll probably just use it for practicing instead of trying to fix it. The board doesn’t boot up at all so once I read your advice I figured it was too much to invest in then just buying a new one. Thanks again
完成的
添加一条评论
1个答案
已选择的解决方案
That is probably not a great plan—for now. Here’s why:
# If the board you intend to fix that is missing that row of caps doesn’t have anything else wrong with it, then it will likely boot right now without them. If it doesn’t, then you have bigger fish to fry.
# Mini soldering tweezers are not the right tool for the job because of the tight clearance. You’d end up making a bunch of solder bridges. A tool small enough to actually fit between the components would not be able to deliver enough heat to melt ground pads—-a catch 22
  1. The right tool for this job is a hot air rework station. To use hot air and work on THIS section of the board is fairly advanced. By the time you have the technical proficiency to successfully work that close the underfilled CPU, then you’d have enough experience to know the answer to this question :)
Microsoldering is really fun, I hope you give it a try. But this isn’t the project you want to start with.
这个答案有帮助吗?
得分 3
1条评论:
@jessabethany Boy do I need one of those Magic 8 balls! Do they make one for diagnosing Macs? Looks like Apple knows what a subversive you are to their infinite wisdom on data recovery. Keep up the good work ;-)
完成的
添加一条评论
添加你的答案
Scott Sanchez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 71
