跳转到主内容
互联网电子眼、智能家庭监控以及WiFi连接摄像头的维修和支持指南。
131 个问题 查看全部
How do I connect these video cables?
I'm installing some new security cameras where our old ones were. One is on a brick wall, with wires being run through where they drilled through the brick/grout. The previous installation had the cables exposed, but the new camera is built to hide them in the wall, so I needed to push the cable back into the wall.
However, it looks like the original installer ran plain cable through the hole they drilled in the brick, then attached a BNC connector to the end. This makes the hole too small to get the connector back through. I couldn't widen the hole with the cable still in it, of course, so I cut the connectors off the end of it and the new camera and fished it up through so I could connect them inside.
Here's where I'm confused: the original cable is coax (used with bnc connector). The new cable on the camera (also with bnc connector on the end) just has a small blue wire and small yellow wire inside. Which wire goes to which part of the coax, if I'm splicing them together? I tried both ways (yellow to braided, blue to internal, and vice versa) and neither worked (I'm running all new wire now but had to stop for the day), but I am afraid trying it the wrong way may have fried something? I'm no expert but get by with YouTube’s help most of the time, but I haven't seen anything that will explain this.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Can you point us to the camera unit you are working with: Make & Model
完成的
Sure, they are zosi cameras (from Amazon).
Bought them here: https://www.amazon.com/ZOSI-8-Channel-We...
Not sure it'll help; I've never heard of the brand before. Haha.
完成的
I have a feeling as if it is analogue, a video balun is needed
完成的
@chriskeeley post some good pictures of your camera's wiring as well as the wiring on your house etc., with your question. That way we can see what you see. Use this guide 在已经存在的问题里加入图片
完成的
添加一条评论
2个答案
已选择的解决方案
OK guys I got it. I'm in US, but apparently in other countries, yellow is positive and blue is negative, according to Dr. Google.
I connected yellow to inner, blue to outer, and it works! I did the same yesterday, but on the old cable. Apparently that cable was bad. Now to get wire nuts that will fit on such small wires...
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Looking at the pictures the cameras have two lines: the video line BNC (Blue) and a power line RCA plug, 12 Volts DC (Red).
Where did you disconnect the cable within the camera or did you just cut off the connector? What did you do with the power line? Hopefully, you didn’t damage it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chris Keeley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 258
