跳转到主内容
This is the 8-inch version of the smaller Fire 7. It includes 1.5 GB of RAM, a faster processor, and an HD display. The Fire HD 8 was released on June 7th, 2017.
Fire tablet won't charge when on, but charges when dead?
Having this issue with my tablet for a while now, It charges when it is dead, but wont charge when it turns on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Having this issue in 2024
完成的
添加一条评论
2个答案
已选择的解决方案
The problem appears to have fixed itself? I dunno what I did, but it’s charging with the old chargers again. :/
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hi @walllam ,
Have you tried using a different compatible charger to see if it charges the tablet when it is being used, to verify that your charger is OK?
The specifications for the charger’s DC output is 5V 2A (2000mA). This should be printed on the charger.
If your charger’s stated DC output is less than this, say 5V 1A (1000mA) or 5V 1.5A (1500mA) it may be that it is not supplying enough current to both run the tablet and charge the battery at the same time.
You may find that at best it prevents the tablet’s battery from discharging, by being able to maintain the battery at its’ current state of charge, by supplying sufficient current to run the tablet without the need for any current to be drawn from the battery.
这个答案有帮助吗?
得分 4
2条评论:
I can get it to charge if i turn it off completely, have tried another charger, all chargers I've tested after I turned it on charge briefly and then stop. Had no problems with the chargers before..
完成的
I'll try another charger that has the right specifications though. might have to buy a new charger.
完成的
添加一条评论
添加你的答案
William 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,074
