What is the size of the 11 screws at the base?
I need to know the size of the 11 screws for the back cover so i can order replacement
Hi,
According to the service manual (p.32, Removal of base cover) the 11 screws are M2 × 3.5 mm, Phillips-head, nylok-coated.
Good hardware stores should have M2 x 3.5mm screws, maybe not nylok coated though
You could also search online using the part number for the screw pack (5S10K38946) for the Ideapad, but you may get other different screws as well as the 11 screws that you want.
这个答案有帮助吗?
过去的24小时: 0
过去的7天: 1
过去的30天: 14
总计 278
