跳转到主内容
加入维修社区 - 创建账户
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
Replacing glass screen & True Tone function
I cracked my phone yesterday, which normally wouldn’t have been a big issue but the crack is located over the front camera which distorts the lighting in pictures. I don’t think the LCD display is damaged and that only the glass part needs to be replaced. However, I did some research and found that True Tone disappears if you get it repaired by a third party (non Apple). Is that still an issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
If you have access to an Ambient Light Sensor programmer, then you can copy over the settings from the original screen to the replacement one. Otherwise, you may want to have this done by an independent repair shop or by Apple in order to retain TrueTone.
这个答案有帮助吗?
得分 3
1条评论:
The repair shop I’m planning to take it to isn’t an “apple authorized” place, however. Would that still disable True Tone?
完成的
添加一条评论
添加你的答案
Smm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 840
