跳转到主内容
SodaStream Source is a new way to create soda in the comfort of your own home that allows you to personalize your beverage and make only the drinks you want, avoiding all the extra bottles.
21 个问题 查看全部
Why does water squirt everywhere when carbonating water?
I have been given a soda stream as a birthday gift which sprays water everywhere when you try and carbonate water. There is a small red/orange peg about 5mm long loose in the box, I’m wondering if this could be the culprit? I don’t have the receipt as it was a gift and the purchaser doesn't’ either and doesn’t live in the same country as me. It seems a waste to chuck it but it’s of no use to us in its current state. Any advice?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
3条评论:
I'm wondering if it has to do with how much carbonation is in the charge bottle. Mine only does this when the charge bottle is getting low. But it's extremely annoying and messy and wish we got answers @sodastream.
完成的
Same problem, I have double-checked everything. Only one thing left to do. Send it back
完成的
This problem after several years of faultless use has appeared
Using glass bottles in an expensive version.
Can only imagine it’s the seal between the sodastream and the top of the bottle.
Perhaps need to exchange the seal but how?
Any instructions?
完成的
添加一条评论
1个答案
If your SodaStream Source is leaking during carbonation, see the SodaStream Source is Leaking During Carbonation problem page. Common problems include the carbonation bottle not being inserted in a completely upright position, not fully attaching the bottle, and using a starting liquid other than plain water or unflavored carbonated water.
这个答案有帮助吗?
得分 0
4条评论:
This answer does not fix the problem.
完成的
I agree, it does not fix the problem
完成的
This is the stupidest answer that resolves nothing. It’s the o-ring and neck holder. But how do you get the parts?
完成的
Useless answer. We all assume that the instructions shown in the guide have been followed. Same issue here. In my case, the water bottle is correctly inserted and pushed up. When empty, the plastic claws around the nech hold the bottle tightly and this doesnt move, no up-down play. Once filled with water, the claws cant even stand for the weight and the bottle becomes loose, an up and down play appears, creating a gap where the water spills through very violently. A real mess. The device is clearly faulty, needs replacing.
完成的
添加一条评论
添加你的答案
Alex Richardson 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 66
过去 30 天: 282
总计 15,020
