跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
150 个问题 查看全部
Ipad won't connect to home wifi
All Apple devices will not link up to home wifi. Changed password wifi and still no connect. Rebooted system and reset Apple products network system and no connect. Advices wifi password is wrong. All other android devices connected no problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
"No connect" is too vague; more details and information is needed. Are you getting an error message? Is it not seeing the network? You say "All Apple devices" but specifically call out just an iPad 6; is it just a single iPad or are there other devices that can't connect? Can they connect to other wifi networks?
完成的
添加一条评论
2个答案
Hi,
  1. Go to settings (app)
  2. Then select “General”
  3. Scroll down and click on “Reset”
  4. Now click on “Reset Network Settings”
  5. Go back to “WiFi”
  6. Select your WiFi
  7. Re-enter password
这个答案有帮助吗?
得分 0
添加一条评论
common problem check ur wifi conection with another apple device if conects then safe mode ur ipad and delete the most recent app u installed or update it and then boot up as normal also reset ur wifi
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
roroeow7 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 438
