跳转到主内容
The 6th-generation Surface Pro, released in October 2018. Available in platinum and black. Model number: 1796.
35 个问题 查看全部
Can I use the display unit of the Surface pro 5 for pro 6?
Hi,
can i use the Display of the pro 5 to fix my shattered Pro 6 Display?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I'm going to give a tentative "yes" with the caveat that I'm not speaking from direct experience.
Looking at pictures of replacement screens for both the Pro 5 and Pro 6, the cabling looks to be identical. The specs (resolution, physical dimensions, etc) for the screens are also the same. I also found part number "LP123WQ1 SP A1" being sold on eBay as a replacement screen for the Surface Pro 6 *AND* the Surface Pro 5.
完成的
添加一条评论
1个答案
最有帮助的答案
No you can’t, the Surface Pro 5 and Pro 6 displays have different touch controllers and are not cross-compatible.
这个答案有帮助吗?
得分 1
1条评论:
I have installed the pro 5 display on a surface pro 6 without issues. I’m not sure sure where you got your info from but they are 100% cross compatible.
完成的
添加一条评论
添加你的答案
ykf kaanf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,814
