跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2686 个问题 查看全部
I replaced my phone battery, but now the screen is unresponsive. Help!
I have an iPhone 6s and I replaced the battery, but now the screen is unresponsive. All of the connections are secure so I’m not sure what to do.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Did you unplug the battery before you removed the screen cables? Battery should always be the first component to disconnect before any repair.
这个答案有帮助吗?
得分 1
添加一条评论
Check all the ribbon cables and ensure none of them are ripped or damaged, they’re very fragile. Then check all the connectors themselves for any bending or damage. When you connect the screen connectors, be sure to press in first on one side, then the other. Don’t press in the middle or they can bend. They should click in on both sides.
Then restart your phone, try a hard reset by holding the Power and Home buttons simultaneously for 15 seconds or so, that can occasionally clear up issues.
Unfortunately if none of that works, you might’ve really screwed up the screen somehow, the only fix is probably going to be a replacement.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
teri salyer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 28
