Non working home button
Hey, got a problem with my iPad after touch screen change. Homebutton doesn’t work but Touch ID does work. Any idea ? :D
That’s odd, usually it’s the other way around - Home button works but Touch ID doesn’t work after touchscreen replacement (when they replace the original home button with a generic in the process).
If you replaced the screen yourself, you need to open it up and check if home button is adhered properly. Does the home button ‘click’ when decompressed?
这个答案有帮助吗?
I ve checked it 100000 times. It clicks, its properly adhered .. :/
Buy a replacement home button and see if that can solve the problem - it will render touch ID not usable though :(
I even tried OEM home button to just get know where is the problem. But with OEM doesn't work Touch ID (logickly) but Home button neither :D
Someone had the same issue on an iPad 5, you can refer to the answer written by @refectio Touch ID works after screen repair but home button doesn't work
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 80
