Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
240 个问题 查看全部
Need missing parts for SSD installation in 2015 iMac HDD bay
I know that this topic has been discussed before and I've read the threads but I need more specific details.
I'm planning on buying a newer iMac in the future as soon as I've saved up the money but that's a ways off. In the meantime, I would like to install a second 1TB SSD for additional, fast workspace and to be able to install other versions of the macOS on additional partitions.
I’m trying to work out exactly what I would need to do this and what it would cost so that I can make an informed decision. Ideally I would replace the 512GB Apple SSD with a 1TB but they’re simply too expensive and I already have a 1TB 2.5” SSD (Samsung EVO 850) on hand.
Note that I do not want or need an internal HDD. I have external drives for large amounts of storage.
The specifics: I have a 27" 2015 iMac with a 512GB SSD. It's my understanding that this particular build (SSD but no HDD) has a SATA connector on the logic board but all of the remaining parts for the HDD bay are missing. This includes:
  • SATA data/power cable
  • Drive brackets and screws
  • The "pin" screws that go on the drive itself
Is this correct? Am I missing anything?
I have the knowledge and skills necessary to perform the installaton. I know what upgrade kit to buy from OWC: "pizza cutter", adhesive tapes, 3.5" to 2.5" bracket, thermal sensor, etc.
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Thanks for all the advice. If you look carefully at steps 32 to 35 of the hard drive replacement guide you can see that the HDD brackets and their screws are already in place. The hard drive has the mounting pins on it. These are the parts I haven’t been able to track down. I have seen the brackets for sale but not their screws or the pins.
The bracket is already mounted! So you don't need it. All you'll need beyond the kit is the pins for the drive its self. Here's the Apple P/N's for them:
922-7001 - Pins, Hard Drive
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
2个回答
最有帮助的答案
The guide shows you everything you will need:
iMac Intel 27" (Late 2012-Mid 2017) SSD Upgrade Bundle
iMac Intel 27" 5K (Late 2014-Mid 2015) Hard Drive Cable
iMac 因特尔 27" Retina 5K 显示屏 硬盘更换
iMac Intel 27" 5K (Late 2014-Mid 2015) Hard Drive Cable张图片
产品
$19.99
iMac Intel 27" (Late 2012-Mid 2017) SSD Upgrade Bundle张图片
产品
$169.99
这个答案有帮助吗?
按维修分数 4
添加一条评论
Yes the list is good to go. If you really want to, you could get a PC power supply for the SSD, since SATA power and data cables are separate.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
Terry Bowman 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 39
