跳转到主内容
Released on July 28, 2014, the Samsung Galaxy S5 mini is a cell phone that features an 8 MP rear camera, 720p display, fingerprint scanner, and water resistance. It has a larger display, increased battery life, and an updated camera from its older brother, the Galaxy S5.
30 个问题 查看全部
Is it necessary to clean inside of my phone if it is fall into toilet?
My mobile phone was dropped in toilet for 12 hours. I dried my phone. But i think there is dust inside. But my phone is running very well. I want to know if the dust is harmful for the future?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi @fixzahid ,
Water resistant doesn't necessarily mean waterproof.
The specs state that it can withstand water up to 1 metre for 30 minutes, which is a bit different to 12 hours submerged!
Whilst there are no problems for now that is not to say that they won't appear in the near future.
Just so that you are aware of this
Personally I would open it up to inspect it but I'm just cautious around electronics and water especially if the device is not new.
Are there any minute cracks in the case or flaws in the seal due to normal activity over time which may have compromised its’ water resistant integrity for example?
Here’s a link to the ifixit Samsung Galaxy S5 Mini guide, if you decide to do this
This link may also be of some help. Electronics Water Damage
Hopefully you also cleaned the outside of the phone appropriately given where it was found submerged and also how the phone is used ;-)
这个答案有帮助吗?
得分 2
添加一条评论
If your phone is running very well, then there is no need to fix anything for now. Samsung Galaxy S5 phones are water-resistant, so being submerged underwater probably didn’t cause significant damage.
这个答案有帮助吗?
得分 1
2条评论:
I feared about the dust,not the water. Will dust create any problem?
完成的
The mechanism in the phone that blocks the water will most likely block the dust as well.
完成的
添加一条评论
Yes its highly recommended you can run in to a lot of issues from it.
If I helped you please accept my answer如何接受一个答案
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zahidul Nahid 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 12
总计 89
