跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2687 个问题 查看全部
iPhone 6S screen went black and came back but battery drains very fast
So i changed Iphone 6s battery for brand new, original apple battery. After that it worked for few hours and screen went black while the phone was still working. 2 days later screen came back like normal but now battery drains very fast.(3 times fully charged during day without usage).
How can i fix it,as battery is new and this is all strange to me?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Several things can cause Battery Drain issues. You will need to isolate some variables in order to get a better understanding of what is wrong. The problem could be a bad replacement battery, excessive current draw from one of the modular components (camera, button, screen) or it could be a problem on the logic board itself.
Here are some things to try:
1.     It could be a bad replacement battery; there are lots of cheap batteries on the market.
·      Try replacing with a known-good battery or order a good one from here.
2.     You could have excessive current draw from one of the modular components; for example, the backlight, a camera or a sensor. You may notice a hot spot on the phone or screen.
·      Fully charge the battery first.
·      Disconnect the battery and then disconnect one modular component at a time to see if you can determine which part is bad. I would start with the front camera flex, then the rear camera, then home button.
3.     If that doesn’t make a difference, then you should try to disconnect the screen to see if it’s the screen or the logic board
·      Disconnect the battery, then disconnect the flexes for the screen assembly, buttons and cameras, leaving only the Lightning Dock connected to the logic board (follow these guides). When you are done, re-connect the battery.
·      Go back after an hour or more and test the condition of the battery. You will need to download either coconutBattery (Mac) or 3uTools (Windows) to see the battery condition.
·      It could also be the Lightning port so you could try the same test as above but with the Lightning port disconnected once the battery is charged (connect it back to test the condition of the battery).
4.     You may have a damaged logic board. This will require a micro-soldering repair and is not DIY. Drops, bends, water damage or using poor quality charging bricks and cables, can cause this.
这个答案有帮助吗?
得分 3
1条评论:
thank you very much,i will try it,i assume its screen or faulty battery but i must check it out
完成的
添加一条评论
添加你的答案
Dusan Todorovic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 412
