跳转到主内容
Designed by ASUS in 2015 as a budget laptop made for travel and everyday uses.
2 个问题 查看全部
Charging port LED flashing green, won’t power on
I replaced my chromebooks LCD screen and now when I try to power on the chromebook the LED beside the charging port slowly flashes green (green for about 2 secs, off, green for 2 secs, off, etc).
Does anyone know what this means? I’m not sure if it signifies something I haven’t connected correctly when replacing the screen.
TIA
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I had the same problem, mine won’t turn in and the battery light is flashing green. I took the battery out and plugged it in to the adapter. It is now flashing green then red, and the power button flashes white but it still won’t turn on. Does that mean my adapter isn’t working properly? I don’t understand why, it’s only a few months old.
完成的
添加一条评论
1个答案
The flashing green LED usually indicates a charging problem. This could be the power adapter, motherboard, or battery.
Shut down the laptop, take the battery out, and try to start the laptop up with only the power adapter. If it doesn't start, you may have an adapter problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mark Naylor 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 56
过去 30 天: 217
总计 11,781
