跳转到主内容
各种形状、大小和颜色的安卓手机的维修指南和拆卸信息。获取DIY修理手机所需的一切。
33606 个问题 查看全部
I will try something to fix my phone
My phone fell into the water and I immediately removed it from the water. When I turn it on, it keeps on shutting down and the screen doesn’t respond. My aunt said that I should dry my phone and leave it for half a month. She said she tried it when she dropped her phone from the toilet and her phone was fine now. I hope this would be true so I’ll try this solution. Has any of you proved it would help save my phone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @gachaz ,
What is the make and model number of the phone?
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not try to turn on or charge your phone and then you need to remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available from electronics parts stores), to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA.
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
You don’t state the make or model number of the phone so search on ifixit to see if there is a repair guide for the phone which may be of some help in the dis-assembly process.
If cleaning it yourself seems too daunting, take your phone to a reputable, professional phone repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 1
6条评论:
My phone is O+ USA but I can't remember the model
完成的
Hi @gachaz ,
Here's a link to a video of an O+ phone teardown.
Whilst it may not be for your model (as you don't know what it is) it might still be helpful.
You might find the model number of the phone printed under the battery. Just a thought.
完成的
Thanks, Jayeff. My O+USA model is BAT40Ai , 8.96 and has a non removable battery.
完成的
Hi @gachaz ,
The manufacturer might say that the battery is non removable to deter the user, but as you can buy a replacement battery which appears as though it plugs in, although it may be glued down, it can be done.
You just have to get to it.
I cannot find a video that shows how to dis-assemble your model phone, but I'm sure that a reputable, professional mobile phone repair service should be able to do it.
完成的
Will my phone finally be okay if they replace my phone's battery? Will it work again like its fine?
完成的
显示更多的1条评论
添加一条评论
最有帮助的答案
First thing first… Never switch on a phone which has been dropped and taken out of water… immediately. Remove battery, SIM & SD card (if any). Let your phone dry by keeping it under a bulb or in a place where sunlight falls (no direct sun light). You should let it dry for 3-4 days. If you are placing it below a bulb ; keep it for 2-3 hours and remove it for awhile and again place it for 2-3 hours.
In Asian countries; we keep these kind of phones in Raw Rice for 3-4 days, as it absorbs the moisture very well. Since this option may not be possible for you, i did my best.
这个答案有帮助吗?
得分 1
2条评论:
Hi @tumharajai ,
This link may be of interest to you
Don't Put Your Device in Rice. Here's Why...
Rice can't stop corrosion or absorb water caught under the shields which may cover some components.
完成的
Hello @tumharajai , I am drying out my phone in a place where the sun shines. Would my phone be fine after I let it stay for 3-4 days there? My phone is O+ USA. Thank you!
完成的
添加一条评论
添加你的答案
Ashley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 76
