Washer filled with water after water shut off
We recently had work done in our apartment that required the water to our apartment only to be turned off. One item that was replaced was the wye connector to the machine. Several days after the water was turned back on we discovered water in the washer. On other occasions when water is turned off in the entire building this has not occurred. A repairman simply ran a short rinse cycle and now the washer is working fine. Could this problem be the result of the work done in our apartment? I have been told that trapped air in the water line to the washer could have temporarily made the fill valve malfunction. Is this possible?
