跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Stripped Screw - Early 2009 MacBook
In the process of replacing the optical drive on my early 2009 MacBook 5,2, I stripped this tiny little screw near the RAM slots. I tried everything ifixit suggested in their video already. Nothing worked. Is there any other suggestions? Maybe cutting the bracket?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The screw is replaceable the bracket is not!
First you’ll need to clean the area of the corrosion from the leaked battery. Try some white vinegar using a moistened cotton swab (Q-Tip)
This screw does have a slight head. I would try grabbing the edge of the screw with a pair of pliers which have a serrated jaw. If that fails then you’ll need to cut a slot into the screen head so a straight blade screwdriver can grab the screw.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Austin Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 41
