跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Replaced charging port and TouchID no longer works
Hi, I have an iPhone SE and it needed a replacement charging port and I purchased one and replaced it. Touch ID no longer works and when I attempt to charge it the device is very strange. If I power it on by the power button and plug it in nothing happens. If I plug it in while powered off it does charge and connect to the computer. I followed the directions on the website everything got replaced easily but now Touch ID is not working and the weird charging thing. Did I do something wrong or is there something i’m missing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Sounds like it could be a faulty charge port flex as the homebutton connects through it also, maybe first check the condition of the connectors and try re-seating the flexs, if its still faulty then you could try the old flex.
这个答案有帮助吗?
得分 1
3条评论:
OK. Weird as I repaired an iPhone 5S awhile ago and it had the same issue. After changing the charger the Touch ID no longer worked.
完成的
Just a thought but have you rebooted the phone with the home button attached?
完成的
When you say reboot do you mean reset as in factory reset with itunes or reboot as in turn the phone off and back on?
完成的
添加一条评论
Might be a bad charge port. If you can, try another one. You don’t have to disassemble the entire device to test a new charge port. Just click it in and see if it fixes the problem. As for Touch ID, there are a few things that could be going on. On the SE, the home button cable is in my opinion, a stupid design. It’s far too easy to pull the screen up too far and damage the ribbon cable. Hopefully what happened is that you just didn’t get it clicked back in correctly. We run into this some times where the button will still register a click but Touch ID won’t work. Try re-seating the connector first. If Touch ID still is not working then it’s possible you damaged the home button and Touch ID will never work on this device again. Apple would be the only one that could fix this as they are the only ones that can link a new home button to a phone.
这个答案有帮助吗?
得分 0
3条评论:
I tried reseating the cable MANY times. I also checked the cable for damage and and found no damage. This happened before on an iPhone 5S that I did the same replacement on awhile ago. Changed nothing but the charging port and Touch ID did not work after. I completely agree it is a really dumb design. The iPhone 6 and above is much better.
完成的
Unfortunately it's possible to damaged the home button ribbon cable without there being any physical damaged to it. As stated before, it's possible to open the display too far when opening the device. Extra strain on the cable could damage something internally. Also, it's not an easy cable to snap back in. In the processes, it's possible to damaged pins in the connector as you are trying to click it back in. This would happen if you try and press it down and it's not aligned properly.
完成的
I would hate for this to be the case as if i took it to apple to be fixed they would charge an arm and a leg because of an authorized repair as well as damage to the home button meaning a while front assembly replacement.
完成的
添加一条评论
添加你的答案
Dudefoxlive 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 511
