跳转到主内容
Released in August 2015, Model number: P01M, Intel Atom Processor Z3530
21 个问题 查看全部
Touch Screen no longer responding
I swapped the battery and that worked fine.
The screen appears fine but now the touch screen isn’t responding any more.
I’ve reseated the cables (I removed to install the new battery) numerous times to no avail. Finally I gave up & tried the “Factory Reset” still no response.
Any ideas? Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Hi,
Have you checked that the cables weren't damaged (broken, fractured etc) when you removed/replaced them?
Do you recall touching the cable ends with your fingers at all when you removed them from the connectors?
Try cleaning the cable ends with a Q-Tip moistened with Isopropyl Alcohol 90% + to clean off any residues left by handling and see if that helps.
If doing this insitu (i.e. disconnect and clean one end then the other) disconnect the battery first to ensure that there will be no problems.
完成的
Thanks for responding.
I didn't check them specifically at first pass.
I didn't touch the cable ends and I just cleaned them with 91% isopropyl alcohol without any fix to the symptom. I don't see any tears or cracks in the connectors now.
I didn't reconnect power before reattaching the cables.
Still looking for a solution...
完成的
添加一条评论
2个答案
Was the touch screen working before you replaced the battery. If not then replace the digitizer.
这个答案有帮助吗?
得分 0
2条评论:
This is hard to tell. I forgot to unplug the charger from the tablet when I switched off the power strip it was plugged into. That let the battery TOTALLY die (I got the battery charging display in the screen but it wouldn't take a charge) so I bought and installed the new battery. PRIOR to the battery dying, it was working fine.
完成的
Ok so try a new digitizer.ASUS ZenPad S 8.0 Battery Replacement
完成的
添加一条评论
Jayeff had some great ideas. I’m going to assume that the digitizer was working before the repair. With that said, did you replace the screen connectors back onto the logic board with the new battery connected first? This can sometimes cause components to get a surge of energy that can damaged them. I would also inspect the connectors to see if any of the pins are bent. This can be easy to do if you tried to seat the connector back on and pressed it down without it being in the right spot.
这个答案有帮助吗?
得分 0
2条评论:
Thank you for the suggestion to check the pins. How do you do that as everything is so tiny!?
完成的
Sometimes you can see something obvious but using a magnifying glass could really help here.
完成的
添加一条评论
添加你的答案
stuff94 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 471
