跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2688 个问题 查看全部
iPhone 6S screen went black and doesnt come back, phone still working
I have removed and installed a new battery into Iphone 6S and booted up, everything worked well,tested all and it went fine. After an hour screen went black, the phone still works but the screen is black. Tried different screen but it still gives me the same black screen while the phone is working fine.
What can i do to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
That is typically caused by damage to the backlight circuit. It will work for a brief moment and then fade to black.
It’s very important to always disconnect the battery before disconnecting/reconnecting the screen assembly. The issue is that the LCD connector has pins that have high voltages (i.e. the backlight is ~20V) and ground in very close proximity. When you fumble around trying to line up the connector plug to the receptacle, you can short out the voltage rail and cause damage to the components in the backlight circuit. If you’re lucky, then only a backlight filter is damaged but other times, the entire circuit could be affected. Either way, this type of repair requires micro-soldering and isn’t really a DIY repair.
To test for this, plug your device into a charger or an iTunes enabled computer. Then shine a bright flashlight on the screen. If you can see a dim image, then the backlight circuit has been damaged. If you can’t see an image at all, then it may be the LCD circuit that is damaged.
You can connect the original, cracked screen to confirm this. If the original screen has the backlight on, then the replacement screen has an issue. If the original screen also doesn't show the backlight, then the backlight circuit is blown.
If iTunes doesn’t recognized the device than the problem is more than just a screen or backlight issue.
这个答案有帮助吗?
得分 3
2条评论:
Thank you, I tried another screen and same thing happened. The phone is working properly whatsoever. What should i do to fix this
完成的
"...this type of repair requires micro-soldering and isn’t really a DIY repair..."
You'll have to find a repair shop that does micro-soldering. It's usually a straightforward repair.
完成的
添加一条评论
I have what seems to be a similar problem with my iPhone 6S, and coincidentally just posted a question about it.  I find that with mine, if I disconnect the battery and then reconnect it, the backlight will come back on for a short time, but then it will go black again.  I can verify that it is a backlight problem by shining a flashlight on the screen.  Have you tried disconnecting / reconnecting the battery to see if it comes back on?   I’ve read several posts that suggest a bad backlight is due to a fuse being blown, but it doesn’t seem like it would work for a while after disconnecting/reconnecting the battery if it were really a fuse.   I might try putting back in the original factory battery and seeing if that helps, but I’m trying to see if I can find any additional information before going through that effort.
这个答案有帮助吗?
得分 0
1条评论:
What is really weird is that it doesnt work on other screen either,i will try with battery and see whats the problem. It really bothers me as it did work for a while and then stopped.
完成的
添加一条评论
添加你的答案
Dusan Todorovic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 256
