跳转到主内容
The Acer Chromebook CB3-431-C5EX is a fourteenth generation Chromebook released in May 2016. The 14-inch Acer Chromebook 14 is made to have a full HD screen and up to twelve hours of battery life.
13 个问题 查看全部
How do I power on a Chromebook with a dead power button?
I’ve got a Acer Chromebook 14 that I’m doing a screen replacement on. The power button was known to not work before the repair. The customer had simply been opening the lid to ‘turn it on’.
I disconnected the battery before doing the repair, and now I can’t get the Chromebook to power-on again when opening the lid. I’m assuming it was in sleep mode before, but disconnecting the battery did a hard shutdown.
I don’t have the charger, but I will try hooking it up to my bench PSU. Does anyone know what I could try to power this thing up?
Any help very much appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Typically opening the screen should boot the Chromebook, if it doesn't there might be some screen issue or it might just not be charged? Did you try plugging it in?
完成的
添加一条评论
1个答案
已选择的解决方案
Soldered a couple of wires onto the DC power jack socket. Thankfully the Chromebook powers on when the charger is connected. Now it powers on when the lid is opened. :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 382
